Plasterboard carriers - are they ok?
30 Mar 2012
Monmouthshire
Any recommendations? Screwfix do a roughneck but it's only 165mm wide, which isn't very generous considering the weight of a single sheet.
I have to shift some 12.5mm plasterboard on my own.
Thank y'all kindly.
Dain
22 Jul 2016
you could always modify it with a bit of ply and upstaged to lengthen it.
It's not too hard to knock one up out of ply but allow for your hands.
hard to beat for a tenner
2 Dec 2013
I have one of those and have used it to carry plasterboard by myself; it makes it much easier.
It’s absolutely strong enough, and being longer wouldn’t help.
I find it helps if you’re lifting it up and putting it down onto a support at both ends (I had a couple of sandbags) so that there is a gap in the middle where you can insert/remove the carrier.
The next option would be something with wheels.
