I recently bought a Toshiba 37WLT68 and the shape of my room means I will have to put the TV up on an angled wall. Please see the pictures below (please excuse messy living room.)
The TV just fits in the space between the window and the recess and the angle accommodates the 2 couches that face the set. SO this means I do not really need an arm which allows me to rotate the TV as I will never need to rotate the set, as the edges will be very close to the wall and the middle area of the TV will be away from the wall, so I thought I could build out from the wall a rectangular flat plinth to attach a flat wall mount, which will save me alot of money. Is this a possibility or should I buy an arm that fixes directly onto the wall rather than a (securely) fixed flat plinth i could attach a flat wall mount to??
Then there is the issue of putting the wires behind the wall, i thought if i made the hole big enough for the plug i wont need to relocate a socket higher up behind the set. Would this be a possibility? OR should I use trunking etc, if that is the correct term? Some sort of pipe-work to put the wires down.
This is how the set is at present, plan to put it slightly higher up, on the wall, and hide the wires behind the wall.
This shows the angle of the wall, at the furthest point the TV will be maybe 20cm from the wall.
View from the other side.
I am worried that building out a flat section to attched a flat wall mount maybe a bad idea, and how best to put the wires behind the wall.
THANKS
iain
THANKS
iain
