Plume management kits.
13 Nov 2005
Yorkshire
Which manufacturers have the plume management kits? I know Glowworm do but is there more.
Also Vaillant (who own Glow Worm). Otherwise there are boilers that have twin pipe flues/air intakes that can be run and terminated in a flexible way - effectively the same as a plume management kit - most obviously Keston but probably many more.
Halstead but they're very expensive, Worcs were due January so should be with us soon...
Last we heard about Worcester was that they are due out the end of this month.
the bore said:
Keston ....dont go there
Why? What's wrong with Keston (apart from crappy suppport bracket, noisy ignition, feeble condensate trap, leaky flue pipe, etc.)?
Why? What's wrong with Keston (apart from rubbishy suppport bracket, noisy ignition, feeble condensate trap, leaky flue pipe, etc.)?
Leaky pump valves, leaky aav, and the leaks.
At least the isolating valves don't leak, when they don't provide any...
And you can't fault their expansion vessels, pressure gauges and PRVs!
But I'm actually rather fond of them, despite their faults. I suppose it's because they're a bit idiosyncratic, like me.
A word of warning from an installer, if you have to call out Keston service engineers (which you will trust me) then make sure the customer dosnt miss the appointment, mine did & Keston kindly sent me a bill for £82-25 call out charge, so i sent them an invoice for the several in warrenty visits i made to repair there crappy boilers.
Up until about a year ago Keston boilers wernt to bad, but recently i have has a lot of problems with faulty ignition & very noisy burners, i will not be installing any more despite the flexibe flue system.
PS. if your reading this Keston then start looking after the installers, no installers = no Keston
Rant over!!!!!
Probably because they are now owned by Ideal for about the last year :rolleyes:
Broag also do a plume management kit.
hopefully all the posters are aware of you twos ideas
seeing as this post was placed TWO years ago
:rolleyes:
:LOL: :LOL:
gas4you said:
That would make it 2008 now corgi! You been on the ciders :LOL:
DOH
I saw 05 it was the month NOT the year
anyway it could be 08 as I am feeling very very Zen and very very very very ****t
