oilman said:I think the mod is saying there is a rule against abuse, but not against insults, so the "yes" and "no" refers to the existence of a rule, not referring to the insults or abuse.
Glad thats sorted then
only ask tounge in cheek
Please note that I NEVER commented on the product itself.What is going on here is a hatchet job on a good product
Quite so - I'm an idiot and just here for your amusement. I have no right to poke fun at simond, but you can slate me in whatever way you like.boasty said:Softus, it's funny, but it has just occured to me that you are an idiot.
Quite so; to wit you'll find posts in which I state exactly that, and the remainder in which it's demonstrably the opposite.There is no shame in not understanding how something works
Request acknowledged and hereby ignored. If you don't agree with what I write, then feel free to contradict it or just ignore it. It's your choice.Go away, read up on it and then you can contribute to what I think has been a very interesting debate, but please don't just sit there poking at Simon when you don't have anything relevant to say.[/i]
ChrisR said:We knew we were deailng with a salesman, now we know we're dealing with a poor one.
This is a double concealed lie.Without an accumulator, . . . , as you reach the max flow rate the working pressure falls off significantly.
It pretends
1) that the working pressure doesn't fall off as you reach maximum flow, if you have an accumulator. Of course it does, any supply will do that. Some do it less than an accumulator system.
2) it forgets that the pressure and therefore flow from an accumulator system drops off as you use it.
The "large volume" of the accumulator is one of its main drawbacks - it's a pretty inefficient way of storing water, as only about half the volume is usable. Assuming you need to store any water at all, that is.Because the accumulator has such a large volume, showers etc, even three running simultaneously, will still be invigourating to say the least.
The "invigourating" (sic) qualities of the showers are not due to their being sourced by an accumulator per se. Any low resistance supply will be exactly the same. But any other method of delivering the same pressure and flow doesn't collapse it as you use it like an accumulator does.
Only if you want to call 1.5 bar impressive. Many if not most "designer" showers are designed for around 3 bar and look very sad at 1.5.Even at 1.5bar, the working pressure is impressive
Yes it does that. But only "better" in one respect, flow, not pressure (as required by those showers). And at huge cost. There are other, arguably better, and certainly more popular methods of achieving the same, and improvements over that.So it doesn't boost pressure per se, just makes better use of what you have.
Try increasing the size of the mains supply. Whatever flow you want, and not a lot of storage space required.
Now we get the real nonsense. Presumably there's a QVC style set of varnished nails to go with it.
Accumulators do not, slightly, in any sense, "negate" pumps.The comparison between pumps and accumulators is a good one, and one we regularly discuss with customers. Accumulators negate negative and positive pressure pumps, are completely silent in operation, store potable water, continue to work in a power cut, and do not wake everyone else up in the house. My company does not specify shower pumps .
Pump noise is not even noticed in many installations. I was at a FLAT two days ago which had a 3 bar ESP pump. The occupants didn't even KNOW they had a pump. There would have been nowhere to put an accumulator. In houses big enough to accommodate huge accumulators there's usually somewhere to put a pump(s) so that noise simply isn't an issue. The bath taps make more noticeable noise.
Any plumber who thinks pumps need "wake everyone else up in the house" is an ignorant one. Or a dishonest one.
Any plumbing company which doesn't offer pumps is a remarkably incomplete plumbing company. "Because of the potential call backs" - try learning how to install pumps properly. You must be very afraid of seeing your customers ? Why would that be I wonder.
Accumulators have been around a long time and can be suitable in some situations, but they're a one trick pony.
Anyone who promotes them as the best solution, and excludes the other options, is deluding his customers and probably himself. We can't put it down to ignorance, which leaves dishonesty, incompetence, or both.
Just the sort of tiresome hobby-horse jockey nobody wants.
croydoncorgi said:Please note that I NEVER commented on the product itself.What is going on here is a hatchet job on a good product
I have only two criticisms:
- an accumulator can only do what its name implies: accumulate pressure that is provided to it, by the mains supply or by a pump. Given the size and cost of the thing and the cost of a booster pump and break-tank, if this is also required, then you have a very big cost, maybe for a small benefit. The same result might also be achieved by alternative, possibly less expensive, means.
- my second point is not about the product at all, only the way it is being sold as an attempted monopoly. As far as I can see there is no novelty and therefore there should be no patent protection. If other manufacturers of unvented HW systems (who are most affected by this monopoly) are prepared to live with it, more fool them! The purpose of patents is to protect, for a limited time, the R&D costs of a new concept or product. This example is neither novel nor required much R&D, if any.
toasty said:Simon,
It really has been educational, thanks for the advice etc...
I'd never considered the possibility of such a device before, and the figures you posted speak volumes.
I think the difficulty with this type of product is that (without wishing to sound rude) there are plenty of people who will just slate it because they don't understand it.
I like to think that for me that isn't the case.
I have 4bar at home and a flow rate of 30l/min from the bath taps combined (hot and cold) and the space (and luckily) money for a large vessel - I'd love to see a larger flow rate (for showers mainly) and increasing the main size isn't really an option, pumps and tanks aren't either.
I still maintain that they aren't for everyone, but in a situation where you have a good static pressure but poor flow they offer a good solution to pumps and tanks without the associated noise and electricity usage.
Cheers
-Dan
oilman said:This implies pumps and tanks are the problem. Accumulators have one significant problem, the inefficient use of space.
simond said:I take it those of you who are mouthing off about challenging the patent are not the same ones who doubted it worked in earlier posts on this thread?
I can't see this Dual Stream patent holding. Accumulators are not new. How RCMs accumulator fits into all this I don't know
Don't think there is any material difference.Where is the Dual Stream accumulators different to others?
