Hi guys.
Here's my dilema : I am in the process of installing a cloakroom in my house. I have fitted a new 'spotlight' arrangement in the room (240V c/w halogen bulbs). I have positioned the new switch for the light outside the cloakroom (typical 10 amp single switch).
i have run a spur from a double socket in the sitting room through a 5amp fused outlet to the switch. Unknown to me I had left the new switch in the 'on' position when I turned the power back on the new lights came on. When I tried turning the switch off there was a blue flash in the switch and the light went off - unfortunately it never came back on again when i tried it. I checked the main fuse box and the 'sockets' breaker had tripped so i reset it. Tried the light switch again but no lights ! I tried changing the fuse in the fused outlet on the spur but nothing.
The strange thing is that every now and then when i turned the power off and played about with changing fuses and switching the light switch the light would work when i turned the power on - but only when the switch was in the 'on' position, i.e if I turn the light off i can never use the switch to turn it on again !! Is it as simple as replacing the swicth to rectify this issue ?
thanks in advance
thanks in advance
