I have a Grundfos Alpha2 15-60 130 pump and I am not convinced it on the correct setting. I had a new additional radiator added recently and the setting on the pump was changed at the time. Since then the system has been noisier than it was before and I find I am having to bleed one of the radiators much more frequently. I know the setting was changed when I had the work done but don't know what setting it was on before.
On the pump from right to left the settings are III, II, I, Auto Adapt and then 4 graduating bars increasing in size from right to left. After the work was done it was left on the setting on the biggest of the bars furthest to the right. I had a look at a manual I found online which suggested the recommended setting was Auto Adapt. I changed it to Auto Adapt but this made things worse and the system was noisier than before.
Cheers
Cheers
