I have some damage to a quite new window frame (see pic below) and wondered if any of you guys have had anything to do with fixing such damage.
A Scaffolding tube fell and hit the window scratching the window pane and gouging the frame.
The scratch on the glass is quite deep so I think it maybe best to replace the pane rather than to mess on trying to get the scratch out, unless you know different?
The gouge is the bit that is bothering me....it's about 10mm long and 5mm high, it's probably about 1-2mm deep.
I could probably flat it out with wet & dry paper but this would alter the profile of the frame so I was thinking along the lines of smoothing the gouge down somehow and then using a filler to bring it back up to just above level, then sanding it back to level with 1200 grit wet & dry, finishing it off with a slight abrasive polish like T-Cut or similar.
But I'm stuck as I can't seem to find any fillers for PVC, any idea what I could use to fill the gouge with and where to get it?
Thanks.
View media item 48085
Thanks.
