Trying to get some information on whether it's acceptable to switch a socket in the same way as a light. For instance, you have an un-switched socket on the ring under the kitchen counter and want to put a fused switch above the counter for it.
The ideal way would be to extend the ring up to above the counter and have a switched spur down to the socket. But if that's not practical, could you run a live up to the fused switch, and a switched live back down to the socket with common neutral only behind the socket?
Only reason I can see it being an issue is that any fault current caused by a nail would be required to go down earth as opposed to shorted to neutral.
Cheers,
Fubar
Cheers,
Fubar
