Hi I have looked at the wiring now and can comfirm:
disconected switch:
2 x brown wires 1 x blue
This is now in a block
Switch I would like to use:
2 x brown wires & 1 x blue
I have also checked a switch in another room which only operates on a one way and it has the same. It is wired as follows:
2 x brown into COMM
1 x blue into L1
I have tried wiring the switch I want to use as follows:
2x brown into COMM & blue into L1 - light does not work
1 x brown into COMM (tested before to make sure it was live)
When I put the voltage tester next to the L2 terminal on the switch when it is wired like this it lights up
1 x blue into L1 - light does not work
Do I need to do anything more with the disconeccted switch
What are you attempting to do? Remove the switch completely or replace it?
Forget what you have in the other the 1 way switch in the other room you are looking at, the wiring is different in a 2 way configuration.
Throw your neon screwdriver in the bin - anything that uses you as part of a circuit should be destroyed.
Yes, you will need to do something with the wires which have been disconnected!
