- Joined
- 22 Oct 2015
- Messages
- 108
- Reaction score
- 6
- Country
Afternoon all...
I'm in the process of renovating our master bedroom in advance of baby #2 arriving.
As part of that, I've stripped all the walls back to plaster, as there was 3 or 4 layers or paper/paint in places...
Unfortunately, that has unearthed what feels like some pretty warn out lathe and plaster... Multiple areas feel loose, and there is quite a bit of pitting etc... Not surprising tbf, as this hasn't been replaced in the last 30 years atleast...
E.g.
So I'm thinking that the best course of action will be for the entire lot to come down - Thankfully it's only one wall though, so ~12m2, including the door opening...
Before I go and hack it all off though, I thought I'd check what the best course of action is...
Can I just remove the existing plaster and lathes and then plasterboard onto the existing studs, assuming they're sound?
Or should I be planning to remove the entire wall including both sides of lathe and plaster and replace with a new stud wall and plasterboard?
The other side of the wall is the landing, so I'd like to avoid disturbing that if at-all possible...
Thoughts?
Cheers
Gavin
E.g.
Thoughts?
Cheers
Gavin
