- Joined
- 12 Aug 2006
- Messages
- 41
- Reaction score
- 0
- Country
Hi all
I wish to remove an old basin from the corner of the bedroom. I understand in the old days it was quite common to have a basin in your bedroom. As if the basin, with its lead waste pipe and water pipes wasn't enough, I also need to remove the old light above the mirror and the light switch next to it. I'm going to do this by sticking the wires into some terminal block and wrapping it in insulating tape, then sticking it back in the wall and filling etc. I understand that terminal or 'connecting block' comes in different amps. I have bought a 15 amp block. Does it matter what amps the block is, and if so what do you think I would need for such a light? Many thanks
PS I may see if there is a junction box in the loft and disconnect from there.
