Removing Silicone sealant!
22 Nov 2006
Buckingham
Good Afternoon :)
How do you remove silicone sealant from around the bath etc.
I tend to use a flat blade and stanley knife.
You?
remove as much as you can mechanicaly, then use silicone eater.
I'm getting fed up of saying this - Forget silicone eater - it's garbage :roll:
Just use a sharp chisel and slide it under both sides of the silicone. Job done faster, better and cheaper.
I can see why you say that, it's not very good, but it's ok for removing the shreds that you can't mechanically remove.
Boons said:
Good Afternoon :)
Boons, your previous post was "How to apply silicone sealant" does this post mean that all did not go to plan, or are you just preparing?
kdLeeds said:
Boons said:
Good Afternoon :)
It went well
I am always looking to hear other peoples methods, If a better idea comes along, Ill give it a shot.
i have been told that if you spray wd40 on the sealant and leave it for 10 minutes it comes off easily.i have not tried it yet .
Considering the post is 5 years old - I bet he sorted it. :roll:
