    Dismiss Notice
Replace a yale cylinder on a UVPC door without key
Discussion in 'Windows and Doors' started by Jonny Vee, 5 Mar 2020.
  1. Jonny Vee
    Jonny Vee
    22 Nov 2019
    340
    Thanks Received:
    2
    Country:
    I got my internal porch door which I 'm unable to find the key anymore. The door is already unlocked but the cylinder won't come out as usually the pin inside keeps it stuck.
    On youtube, a guy snaps it on both sides but to be honest I'm worried to apply a lot of force as I will be damaging the door.
    is there any other method without spending a fortune on a locksmith to get a simple cylinder replaced?
  2. Sponsored Links
  3. What kind of lock, a eurolock?
  4. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,512
    Thanks Received:
    1,913
    Hertfordshire
    Country:
    Drill it out.
    Andy
  5. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,512
    Thanks Received:
    1,913
    Hertfordshire
    Country:
  6. Jonny Vee
    Jonny Vee
    22 Nov 2019
    340
    Thanks Received:
    2
    Country:
    Yes, it is
  7. Jonny Vee
    Jonny Vee
    22 Nov 2019
    340
    Thanks Received:
    2
    Country:
    If I drill out will still be inside as the pin keep it inside.
  8. Jonny Vee
    Jonny Vee
    22 Nov 2019
    340
    Thanks Received:
    2
    Country:
  9. Bit confused, it's unlocked, right, so you need to get the retaining screw that holds it in? correct?
  10. Sponsored Links
  11. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,512
    Thanks Received:
    1,913
    Hertfordshire
    Country:
    Eddie, he has lost the key.
    Andy
  12. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,512
    Thanks Received:
    1,913
    Hertfordshire
    Country:
    He has also lost the 'thanks' button.
    Andy
    • Thanks Thanks x 1
  13. So? it's unlocked? Though I suppose it may well be in the unlocked, but jammed position.
  14. Jonny Vee
    Jonny Vee
    22 Nov 2019
    340
    Thanks Received:
    2
    Country:
    yep. Just found out. I will have a go
  15. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,512
    Thanks Received:
    1,913
    Hertfordshire
    Country:
    Yes, the internal door is open.
    Andy
  16. Jonny Vee
    Jonny Vee
    22 Nov 2019
    340
    Thanks Received:
    2
    Country:
    Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks
    • Like Like x 1
  17. Well, I'm non the wiser, little change there.
Loading...
Share This Page
