I am hoping someone can advise please.
We have a Potterton EP2002 programmer/timer and the slider keeps falling off, so it looks like we will have to replace the unit. We only use the slider, as when they fitted the new boiler it blocked the programmer in (see photos).
I understand that the Potterton EP2 (around £100) would be a direct replacement and not require rewiring. Is it easy to install for a novice and the access issue in the photo?
When our Potterton boiler was replaced, they installed a Viesmann Vitodens 100 boiler and replaced only the thermostat (with an R310i wireless), but not the controller.
Is it possible to easily replace the Potterton EP2002 with a wireless option to go with the R310i, or are we stuck with replacing with an EP2? I know anything is possible with lots of rewiring and bringing in a professional, but will just swap out if there isn't an easy/option to do it myself.
Thank you
Thank you
