Hi
First time on here so bear with me. I want to refurnish my staircase but not sure how to do it. I basically have a straight staircase to landing, with a handrail on the lefthand side which is a long plank of wood which has clading attached to it blocking the stairs in (I will add pictures). Very 1970's. The newal posts are essential 4 x 4inch posts screwed to the outside of the stringer (I can see the screws). The newal at the top is screwed into the wall next to the staircase, but not secured to the staircase. Only the stringers are attached to the upper joist (if you know what I mean). Usually stairs have the newal posts integral to the stiars, in line with the stringer, so that the handrail sits over stringer. In my case if I was to add a hand rail to the newal the spindles would not line up with stringer (base rail) so I think I've 2 options:
1: - Cut a notch out of a handrail and fit it to the newal so that it sits above the stringer - I can then add the spindles / base rail; I think this is within my ability but would look second best, or
2: - I assume that I more or less have an open staircase that someone has added the stair parts to, so I could (if I had the ability), remove the newals (they are not integral to the stairs) and try to cut new newal posts so that they sit over the stringers at the top and bottom and then I could add a handrail and spindles. This probably beyond my ability to do a good job!!
Any suggestions? Has anyone seen this type of stair construction before.
