No John they don't. It's only in the context of 2 way switching.
No it doesn't.Well, yes, and so does BS7671,Marbo electrium consider grey is the replacement for yellow ... And black replacement for blue
You're right - my memory failed me However, as I said to Andy, it doesn't really help us in relation to the present discussion, since it does not tell us which (in either old or new colours) one should use (and over-sleeve appropriately) if one needs to use one as a neutral. ... in both old and new colours, all three of them correspond to (3-phase) line conductors.No it doesn't.Well, yes, and so does BS7671,Marbo electrium consider grey is the replacement for yellow ... And black replacement for blue
I know it doesn't (and I think everyone is agreed about that), but Andy seemed to think that he had discovered something which had a bearing on the choice.It does not tell you because it does not matter.
Before 2004, where a 3 core and earth was used for L, sw L, and N, more than 99% of the time
red was perm L
yellow was sw L
blue was N
There's no denying the above. That's how it was nearly, nearly always done.
We only have to look at the structure of a 3 core and earth cable to see what the equivalent sequence of colour is
red = brown
yellow = black
earth = earth
blue = grey
And is it totally ridiculous to choose a harmopnised black to be the neutral because 'black always used to be neutral'.
That is totally irrelevent.
Harmonised colours bear no resemblance to the unharmonised colours.
They are two different systems, which need to be connected together in a reliable way if only to make things simpler and safe.
People who use grey as the neutral make my teeth itch.
On a similar note, I caught someone wiring a 3P+N machine the other day. With a 4 core SWA they used
L1 brown
L2 grey
L3 blue
N black
In this case of course, neutral has to be blue.
They were going back to the unharmonised way, trying to make it the new colours resemble the old colours.
I went berserk.
Fair enough - so what are your teeth happy with - grey?I meant to put '(in a 3 core+earth cable) People who use BLACK as the neutral make my teeth itch'.
Kind Regards, John
With regard to the design of the cable could you (anyone) explain the reason and/or significance of the layout when being used in single-phase installations?red = brown
yellow = black
earth = earth
blue = grey
yellow = black
earth = earth
blue = grey
It obviously doesn't matter in three-phase.
That is - line, line, cpc, neutral.
Would not - line, neutral, cpc, line be 'safer' for ADS in the event of a fault?
If you're thinking of cable penetration or melting insulation, then yes, I would have thought so, but wouldn't:With regard to the design of the cable could you (anyone) explain the reason and/or significance of the layout when being used in single-phase installations? ... It obviously doesn't matter in three-phase. ... That is - line, line, cpc, neutral. ... Would not - line, neutral, cpc, line be 'safer' for ADS in the event of a fault?
