I just found that CET at Watford, a recon board outfit, do recon pcb boards for the Gledhills. £81 inc delivery.
http://www.cetltd.com/search.asp?srch=Gledhill
I doubt you understood a word of it. You do make me larf.Yawn.
A standard vented or unvented cylinder is far simpler as it has no pumps, heat exchangers, PCB or any of the other unnecessary components that thermal stores do.There is no user or installer setting of anything and minimal mechanical parts inside the box; there is nothing inside the box except three quality pumps, a pcb and three sensors. Fire and forget. How simple can it be.
PullerGas, wrote "The Navitron Solar forum is full of them too!!"
I think it was that forum, where one fellow fed into a normal cold water tank fed cylinder I think a 100 foot coil of 15mm plastic Polybute pipe, and used this to instantly heat a mains water fed shower, as what Bernard has. Apparently it worked very well and very cheap to do. The pipe was rated for high temperatures. I don't know what the downside would be as the pipe is softer when hot. The expansion and contraction must prevent scale building up on the pipe.
