Hi, apologies if this has been asked before.
In my living room, we have 3 x R50 mains powered SES spotlights. They are controlled by a 2 gang dimmer switch (1 switch controlling 2 of the spots, with the second switch controlling the 3rd). One of the fittings has failed and needs replacing. I want to retain the current set up with the 2 dimmer switches and effectively change like for like. All the work will have to be done from below.
Being older fittings, the holes are quite large, but I see you can get modern oversized spotlights so assume no issues there? I do have some questions though...
1, I notice you can get either GU10 LED or MR16 Halogen fittings. Is one better than the other?
2, I was assuming that GU10s would be better as they are mains driven and avoid the need for transformers? I believe you can get LED dimmable bulbs?
3, I've seen in some forums talk about firehoods - are these required? The current lights don't, and they were fitted by a qualified electrician. Can you get firehoods that can be fitted from below?
Anything else I need to be aware of?
Many thanks,
Clive
Many thanks,
Clive
