Replacing Socket in the garden
12 Dec 2016
I have a double socket in my garden installed by the builders.
It is a GET GWP3020., like in the folllowing link:
http://cpc.farnell.com/get/gwp3020/2-gang-switched-ip55-sckt/dp/PL08021
It does not seal the plug when there is something plugged in. I want to run some garden lights from it, so I want to replace it with an IP66 type socket.
Do all these sockets have standard fixing hole distances?
So I could simply remove the socket and rewire without having to drill new mounting holes?
Or are they all different?
You can't rely on the screw spacing being the same.
I find the Crabtree one very good, they're a major manufacturer so may have a dimensioned drawing somewhere on their website.
The MK weatherseal is also good, but may be more expensive.
BTW consider using stainless screws to fix it to the wall. you can buy small packets on ebay at negligible cost.
p.s.
Unless the socket is fed from an RCD-protected circuit, you will need an RCD socket.
My vote would be for masterseal. They're just a dream to use and fit compared to anything else I've ever used. The wiring space is insane and they're easy to fix.
Whatever you do, do not buy a GET socket. They're on the shelf in a couple of our wholesalers and the fixing screws are so recessed you have to find a slim screwdriver to screw then to the wall, and when you try and screw the socket front back they're under the sprung hinge for the lid so it keeps biting you
My vote would be for masterseal. They're just a dream to use and fit compared to anything else I've ever used. The wiring space is insane and they're easy to fix. Whatever you do, do not buy a GET socket. .... when you try and screw the socket front back they're under the sprung hinge for the lid so it keeps biting you
Have Masterseal changed? Whilst I agree that they are otherwise fantastic, I feel sure that the ones I have used have always 'bitten' in the manner you describe.
Kind Regards, John
Kind Regards, John
Fitted one of each today, the cheap one was actually Click not GET but the design is one and the same. MK sockets do not have a sprung lid, or at least, it's not as vicious as the cheap ones. It will fall down as your trying to fix the socket front in place, but it doesn't hurt.
Also, you fix the MK to the wall/post etc with the front completely off so the lid is not in the way then, Click you screw to the wall once the socket is all put together, so double the amount of biting time.
OK, I'll give you that the MK springs are not as vicious, but I personally haven't seen one without some spring.
Yes, that is a definite pain. However, I've seen some (can't remember which) non-MK ones that also have a 'back box' that can be fitted before one puts the front on.
Kind Regards, John
