I would use 500 H x215 W x 300 D,
What does the 'D' stand for?
Jason, I don't know where you get the 150mm minimum bearing from. Wherever it is it's just a generalisation probably aimed at the diy market.
Where a lintel has a clear span of 1200mm or less the bearing length may be reduced to 100mm.
Or approved document A page 25
but now I've seen the work the builders have done I'm a bit concerned about its safety
How do we know that the beam is actually supporting anything? The top right-hand pic seems to show a black void, with just a wire hanging down. The thing on top of the beam might be a piece of timber intended to cover the gap. Is there actually a wall above the beam? Do the floor joists run parallel?
I'd ask for my money back.well, that is exactly the calcs I had to use on only a 2.9 m span...
Probably with a partition running along the line of the joist.Sounds like the beam is just supporting floor
500 deep beam for a 4m opening!![]()
I'm still chuckling!![]()
Are all three stories balancing on the one beam?Apologies for misleading- it is a 3 storey house hence size of beam
