It was actually the IET (as co-author of BS7671) that I asked - but, no, they haven't yet 'got back to me'. However, it's only been a few days, and my experience is that it can take them ages to respond (if ever) to such queries (I have several 'outstanding queries' to which they haven't yet responded, which I remind them about every few months!).Sooooo...... Have BSI got back to you with their reply when you asked them about this issue?
Precisely.That would probably be true if there were 'mandatory rules'.
Was it mandatory for the authors of BS 7671 to comply with it...
But I genuinely would like to know what rules govern the wording of British Standards, and whether they are mandatory or advisory.
Are there rules which the writers must follow, or just conventions/guidelines which they should preferably follow?
In a wider perspective it matters IF the "rules" quoted are actual, mandatory, hard-and-fast rules.
If following those rules is mandatory, then...
I've not had a chance yet to look at the info Detlef has provided - some time today, I hope.However, we need some expert input, since I'm not even convinced that they are 'rules', let alone mandatory ones - it could be more like 'guidance' as regards 'conventions'.
Yup.All that matters to me is that the document should be clear and unambiguous, regardless of any issues regarding rules, legalities or funding.
I would have thought that defining within the document the meanings that the 'shall/should/may etc. words' have within the document (and then abiding by those definitions) would be the simplest way to ensure that it was 'clear and unambiguous'.
I suppose that both meanings of the word apply there - i.e. it is possible that any of those three voltage sources could be used AND it is permissible to use any of them - so there's not really any ambiguity.
Far too late. Whichever was the original, AFAICT both meanings have existed for hundreds of years.I think the dual meaning of may must be an example of the dreaded "evolution of language"; clearly too late to alter.
Except that some of your examples are so tortuous that they would never be used.So, clearly confusing if you don't know the rules already.
IMO, anybody who cannot tell from the context whether "may be" means "might be" or "is permitted to be" when it matters probably has no business trying to do electrical work.
The Shorter Oxford has that entry - basically says 'may' = 'can'.On the other hand, if I understand correctly what I'm reading, in etymological terms, the word 'may' derives from an Old German word meaning "have power", which sounds a bit closer to the 'permission' meaning than the 'possibility' one
You may be right,Yup.
And I'm not aware of any instances in BS 7671 where the meaning of "may" is not 'clear and unambiguous'.
Not necessarily.Ok. but "he may..." could also mean that he has been given permission which also implies it has not happened yet.
I remember being taught that the difference between "will" and "shall" was one of prediction vs intent/instruction (not necessarily that way round).Could it once have been (lost now) like 'shall' and 'will' conjugations, i.e. I was taught -
I shall
You will
He/she/it will
We shall
You will
They will
and vice versa.
That seems to have been lost, so who can say what is right.
¶7 Verbal forms for expression of provisions, contains the section I quoted previously.
If that is directed at me, the answer is most definitely no - and, for what it's worth, I'm actually currently very busy with work.I take it your having a quiet week at work and needed to nitpick something so the likes of BS7671 got thoroughly dismantled, did you go through it and highlight certain words different colours, make lists on how many times they were used and spot any other imagined issues?
