Hi all,
I got a cable running into an airing cupboard in which I want to install a network switch and AC/DC adapter for a camera. The cable 2.5mm runs direct from consumer unit which is wired to a 16A fuse in the CU. Currently cable just terminates into a switch that I assume was used to power the old boiler.
I want to add a dual socket and a FCU as a safety measure.
Would wiring shown below be ok? Can you supply double docket from a single FCU?
Thank you
Thank you
