running cable through a void that is inaccessible?
22 Mar 2009
London
hi,
i wan to create a spur from an already existing ceiling rose (capacity permitting) but I'm not sure how to get the cable from one hole to another. i do not have access to the void above the intended lighting fixture, as it a small loft space above a side return off an old victorian terrace. Apart from creating several small access holes that run in series or ripping the whole ceiling down (hahahahaha) i am stuck for options, any tips?
manglehead
2 holes, one for the existing light, one for the new one...
and a trained rat with a string tied round it???
put it up one hole, and waft cheese at the other?
thought about training my dog but the hole would be too large.
in all seriousness is there a professional solution, this problem must come up in many retro fitting older properites?
That actually is a profesional solution! Can't say I've used it myself however, I generally stick with cable rods / lid from PVC trunking and fish tape.
thanks for the reply, i didn't mean to offend anyones professionalism, but could you expand on the:
Fuse carrier: The movable part of a fuse designed to carry a fuse link - part to your explanation, as i didn't really understand how to use them all together?
Ignore the fuse carrier bit.. its his signiture quote and appears on every post he makes... he just happened to have a slightly off beat sense of humour :lol:
If you have two holes into a void with no joists blocking the way in between and need to get a cable between them, then you need something rigid to push across, if you have them, then a set of cable rods ( http://www.tlc-direct.co.uk/Images/Products/size_3/FXCRSSX.JPG ) is the tool for the job, if not, you can use a bit of lidding from pvc trunking, you'll probably not need a nylon draw tape ( http://www.tlc-direct.co.uk/Images/Products/size_3/CODT.JPG ), but depending on the situation , especially with bigger cables its sometimes easier to use the rods to pull the tape in, and then use that to pull the cable in.
I'm sure that many of us on here have spent many a happy hour feeding a coil of string into a hole then trying to fish it out using an old wire coat hanger taped to a piece of oval plastic conduit.
There's no secret to it really.
