    Dismiss Notice
Scantronic 9100
Discussion in 'Alarms, CCTV & Telephones' started by nortonbob, 5 Nov 2013.
  1. nortonbob
    nortonbob
    19 Jul 2011
    20
    Thanks Received:
    Country:
    Hi, I had this system installed about 20 years ago,with a remote keypad, the system works fine inside the house at present,some time ago the strobe overheated (got damp) and blew a fast blow fuse,at the time this fuse blowing also unpowered the keyboard so I pulled a wire off in the main board that stopped the outside alarm. Can't for the life of me remember where it goes now!!I have fitted a new strobe in the outside box ,the 5year battery is still ok but if it all works I will replace. I have all the paperwork ,engineer code, diagrams ,installation book etc, Do we have on board someone who has experience of this installation ? I can send a foto of the board (mobile phone) and terminals where I think the wire was moved. I can get into it all but my old brain just refuses to work now .I have test equipment from when I used to do just about anything.
  2. sparkymarka
    sparkymarka
    16 Feb 2011
    7,672
    Thanks Received:
    1,177
    Sheffield
    Country:
    Wire for strobe or bell ? The 9100 strobe is a relay so it's a wire from aux to relay and back out to strobe it also has a bell relay but most people use the bell trig. Post a picture of pcb.
    • Thanks Thanks x 1
  3. nortonbob
    nortonbob
    19 Jul 2011
    20
    Thanks Received:
    Country:
    Hi Sparky,i think it was a wire for the bell,but seem to remember that the bell box battery/cap took ages to die,so maybe did not get the right one!!. I have to take down a DT420 sensor to decorate ,how to disable the internal sounder?.
  4. EightyTwo
    EightyTwo
    14 Feb 2012
    1,117
    Thanks Received:
    169
    Cambridgeshire
    Country:
    Put it in engineers mode and it will ignore the tampers. You could take the PIR off the wall but leave it connected or you can disconnect all the wires and just leave the cable hanging out. If you do the latter, remember to insulate or isolate the Aux 12V supply.
    Leave the panel in engineers mode until the paint has dried and you've put the PIR back. Then it's 99<ENTER> and you're ready to go!
  5. DIYnot Local
    3 Sep 2019
    Country:
  6. Sponsored Links
Loading...
Share This Page
