hi guys new post. just in the process of installing another alarm system for a small flat. the system is a scantronic 9651. not really used this system for a while. Anyway I plan to install a flashguard xtra external sounder and an elmdene 400 internal sounder. not too keen on the speaker, I mean they are loud but not that loud).
so I plan to connect both the elmdene 400 internal sounder and the flashguard xtra to the bell output (o/p1). having looked at the specification for xtra the bell current is 320ma and the elmdene is 180ma, so the total bell current will be exactly 500 ma. will o/p1 just be able to run this? or will i blow the bell fuse. if so can i use o/p3.
I would like them to both sound at the same time when the alarm triggers and i would prefer to keep the flashguard xtra on sab mode. will this be okay?.
my system set up plan is
1x scantronic 9651 with the 9930 keypad
3x aritech ev125-p
1x elmdene int400
1x flashguard xtra
1x door contact
1x double push panic button
cheers
3x aritech ev125-p
1x elmdene int400
1x flashguard xtra
1x door contact
cheers
