hi! does any one know a good shed roof ,not felt to last and the cost ;i have a 10 by 13 shed and need it to last 15 to 20 years!
hi! does any one know a good cheap roofing material other than felt which will last atleast 15 years in all weathers ?
quite right in what you say;however i have used the most expensive felt going so did not know what was on the market! I shall wait for your advice! cheers from a tight wad!hi! does any one know a good cheap roofing material other than felt which will last atleast 15 years in all weathers ?
it does make me smile when someone asks for a cheap roofing material, and then in the same sentence, expect it to last 15 years, outdoors in all weather.![]()
there are cheap felts and there are expensive ones. 'you gets what you pays for'.
stop being a tightwad and cough up the dollar!
cheers ! i will look in to this,i have spent 100 notes on the roof and it has lasted 3 years?will probably last 3 to 5 years with cheap mineral felt
my shed is the same size as yours and my neibour with a gas cylinder and around £160 worth of felt [base layer x1 mid layer x2 and top layer x2] should last 15 to 20 years so at £12.50 a year including a good whack for his trouble a lot cheaper than replacing it ever 3 to 5 years![]()
thankyou will do!You could also use felt adhesive at the corners/edges, and this should help to keep it in place.
Wickes used to sell a mastic for sticking felt down. Tthats what I used over 20 years ago and never had a problem. If you fix with nails it will only last a few years.
