- Joined
- 20 Dec 2013
- Messages
- 149
- Reaction score
- 36
- Country
Indeed it is a dual element temperature controlled dual stat, as the control stat reaches cut-off temp it switches over to the overrun stat and in effect continues to run the pump until the factory set cool down temp is reached then pump switches off - but there is one main difference on switchover - the burner will not (read as 'must not') light until control stat comes back into function and the pump still continues to run per demand - if the pump does not clear the residual heat within 30 to 60 seconds then viola!
...the saw tooth effect.
