single switch required for a double pattress box
6 Jan 2007
Essex
I mean is this dull or what?
but anyway I have a white double pattress box on which is presently mounted a single push on/off dimmer (from home automation)
and I want to replace the dimmer with a single on/off switch. But it does not seem to be possible to buy a faceplate with a single on/off swich designed to live on a double pattress.
I mean I could buy a 3 gang switch - but then you have to explain to people that two of them switches just shouldn't be there ...
There must be a simple solution out there?
You could go for a 3 gang "grid" switch and insert 2 blanks in the other inserts.
Or you could change to a single patriss :wink:
