Hope that explains my madness!!
or use an electrak socket designed for the job
You mean the kind of twisty things? Kind of like these. When I was in Dubai, we wired up our office with a similar thing where you could shove sockets into a kind of trunking wherever you like.
But for a one off socket for a simple connection I think it might be overkill, but I'll have a look at costs. It appeals to the innovator in me!
That's certainly the common sense view of this issue. However, for those with more formal minds/concerns, does anyone know whether BS1363 has anything to say about this?cannot undersand what the issue is about a ceiling mounted socket whether single or twin.once plugged in properly will not come loose unless you have a lot of vibration.will not arc.just go for it
I don't have easy access to BS1363, but I think that some of those here do - so hopefully someone will be able to tell us in due course.if you can find it john let me know
Something
It's obviously primarily to do with specifications of the plugs and sockets - including temperature rise in use (which will presumably depend on orientation) and, I imagine, pin retention. If you're certain that it contains nothing about orientation of installation then fair enough, but it would not be unthinkable that it might mention such things.hi john.bs1363 is more to do with legal and illegal sockets ie insullgated earth pins etc.nothing to do with socket positioning.
Off the top of my head, I can't think of anything directly relevant in the regs either - unless, of course, the manufacturer's instructions advise against ceiling installation.nothing in regs against ceiling mounted sockets.
Do you mean FCU? If so, why would you be strongly against it?hi would strongly be against fsu though
Fair enough, but that's not any different from the situation when any IEC lead is unplugged from the load whilst still plugged into a power socket.would not fancy hard wiring television unit.new televisions come with kettle lead connections.to disconnect for whatever reason some people will unplug from the tv still leaving the lead live
