i am about to purchase either 150w or 250w x 7off sodium floods.
are sodium lights of discharge type?
if so would i have to use a correction factor of 1.8 for the total load?
the lights are to be wired on the same circuit using a 20AX waterproof switch along with a 10A type c mcb.
the length of the cable run is long, at 150mts. what would the correct size cable be for this installation?
cables to be ran clipped direct, not bunched.
does all this sound ok?
also does the 70w sodiumlights give off much light? if so what could you compair it to?
thanks
thanks
