How much ventalation space do you need around these lights .As its a new build the loft has 250mm insulation.
I thought may be use 110mm soil vent pipe to vent the light and stop the insulation touching the light??
The halogen spotlights get very hot so I would worry about your soil/vent pipe melting. Aluminium pipe used for boiler flues, extractor fan ducting etc. would be better.
I would love to see 6 terracotta pots come through the ceiling with the halogens lol if it got slightly damp plaster board he he.
And btw im not an electrician but when I did fit 4 halogens in a kitchen (last property) they got so hot you could cook a complete roast dinner from just 2 of them - before you say anything the transformer ratings and fit was correct.
those black fire caps seem to do the trick in screwfix but expensive..
I would use metal tube as suggested and leave open at the top for heat dissipation - also warm your loft up lol if fitted there
