This is how I set the idle, or slow running speed screw.
Get the machine running - use the mechanical throttle stop screw to achieve this if necessary, but have the machine running pretty slow - if it allows this!
Turning the idle screw in weakens the mixture.......the engine should speed up but it will have no power when you squeeze the throttle. Turning in too far will cause the engine to stall.
Turning the idle screw out makes the mixture richer.......the machine should start to slow up and maybe there will be a little smoke. Turn the screw back in at that point so the machine just starts to run slightly quicker and that should be it.
I hope this helps, but these carb settings are pretty critical!
John
John
