Replaced the following today.
Tank grommet.
Inlet & Return fuel pipes.
Inlet filter on pick up pipe.
Question 1
Why when pulling the cord 10 times it doesn’t start BUT small squirt or wd40 with air filter off & down the port pulls & starts straight away ?
Question 2
When making a mix of fuel / oil every time will not be exactly the same.
I understand about seizing it up or white smoke BUT does this also affect the way the strimmer runs in respect of having to adjust the mixture ?
Question 3
Tick over is controlled by the screw that touches the throttle plastic piece on top the carb.
On the carb just above the inlet fuel pipe what is the name of that screw adjuster. This is the one I adjust when setting the mixture / tick over whilst holding down the throttle.
Tank grommet.
Question 1
Question 2
Question 3
