- Joined
- 8 Mar 2010
- Messages
- 321
- Reaction score
- 7
- Country
What ho all self isolators,
I have been researching a Tamper Fault Lockout message on my Accenta G4 Mini RKP and can find lots of solutions, but don't feel any further forward in solving the issue.
At the weekend, I moved the garage RKP about 6 cms because it was too close to a wall hanging ladder. I did post a question about turning off the alarm https://www.diynot.com/diy/threads/reposition-rkp.545143/
All went well, reactivated the system then had to assemble the RKP case again. (The plastic tabs had snapped off (UV, 10 years old RKP) so was applying some tape to hold the front to the back.) When I removed the front, the alarm did not activate, so did not have to enter my code.
Got things straight and reassembled again and all is good; tested the alarm, it is set and the bell operates.
However, for the last two days, every now and again, the RKP sounder had gone off and shows Tamper Fault. My code and a reset and all is good.
Tonight, it happened again, and now it shows Tamper Fault Lockout. Since I only moved the RKP, I assume the RKP tamper spring / micro switch is at fault. I did not disconnect any of the wires when I actually moved the RKP.
What should I do to reset the Lockout situation? As an aside, I installed the alarm myself ten years ago and it has been working just fine.
Thanks and toodle pip
