- Joined
- 25 Aug 2018
- Messages
- 64
- Reaction score
- 1
- Country
Hi people,
I have a Texecom 64M with SmartCom and a SmartKey..
The SmartKey is set to user two with the unit master set as user 1 - User 0 being the engineers slot.
The SmartKey TAG is attached to the Master - user 1.
If I arm from the SmartKey it all works and arms as I leave the front door. However: when I return I have to use the SmartKey to disarm - that's okay.
However when I arm from the Master user using the 5678 code (Not fully installed yet), leaving all works but on return I can only disarm using the SmartKey keys and not the TAG, I can't even use the user code, 5678, - it's asking me to use the TAG but again that doesn't want to work.
Any ideas? I've probably switched a switch on/off via Wintex!!
As once can see I'm no an expert.
Another thing: I've just ordered a set of flashing lights to install into the alarm box, via eBay. Said it would last 10 years and only cost £10.
See: https://www.ebay.co.uk/itm/Decoy-Al...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
I hope this will save me money not having to buy Lithium batteries as often as if one leaves the sounder box internal lights flashing.
Take care,
Bob...
Take care,
Bob...
