Texecom 64M will only disarm with smartkey
The flashing lights turned up and I managed to retro fix them into a Odyssey box X-W with no problems - used the empty sounder area to hold the batteries - I can send a snap if need be...
This, page 61 just tells one to go to page 38 to hold off sounders but page 38 still doesn't tell one how to hold off the sounder.
From page 61: This WILL NOT put any Ricochet sounders into hold off mode. To put any sounders on the system into hold off mode. See page 38
From page 38:
Hold off mode should be enabled if replacing sounder
batteries. See page 61.
Another thing, whyme, i'm trying to part arm at night and have ticked all the boxes to silent arm but still get the control box making a sound as does the keypad - Can I set completely silent mode arm or does one still have to have these beeps?
Got these bits with the Texecom Kit 0002! Does anyone know where the square bit goes - the round bits are to cover the controller box screws but the square bit???
is that done in areas- options- part arm silent-(enter areas)? and/or keypads-keypad sounds
The square bit goes over the fuse ( 240 v) block ....or normally ....the bin!
Are you talking about the keypad bleep on silent set ?
I've fixed the keypad noise by un-ticking the Keypad Entry, exit and chime see below.
Still need to stop the control box beeping when I part arm at night - any ideas?
Still can't workout how to put the Sounder into 'Hold off Mode' to stop it sounding when I try to change the batteries??
Again any ideas?
