Proper reel brake, no plastic fails here.
I got fed up of winding and unwinding the crap diy shed cable drums, so made 2 lengths of cable from 1.5mm rubber HO7 RN-F, one about 8 metres for internal work, one longer for outside.
The cable shall be fully unwound when in use.It is a brake to stop the drum turning and twisting the cable that's plugged into a socket.
Oh for heavens sake!The cable shall be fully unwound when in use.
Not necessarily. They sometimes come with indications of the maximum safe loads when wound and when unwoundThe cable shall be fully unwound when in use.
Is it to stop the cable twisting around the spindle if it hops off the side of the drum?
I shall not fully unwind the cable when not necessary.The cable shall be fully unwound when in use.
Yes, most definitely, Hence:Why does an extension lead need a brake? Has anyone ever had an out of control one?
I am in the habit of using (locking) it between uses to stop it unrolling during transportation and handling. The remaining 50%: as described before where the thingummy was never there or long gone, with those I tend to run the end of the lead round the upright tube a full 360° so the cable gets trapped between the drum and tube to act as a brake.
Only if you also have a wossname adapter.I have a thingymebob, will that do?
"IF"??Is it to stop the cable twisting around the spindle if it hops off the side of the drum?
What, even when the load doesn't exceed the rated maximum for a fully wound extensionThe cable shall be fully unwound when in use.
