To sleeve or not to sleeve??
  • Thread starter Thread starter DeltaT
  • Start date Start date
So is the area between first floor joists a duck....no sorry a duct??
So that's the punchline (point) dick??
I knew it wasn't a joke, I was just wondering why you were asking the question.
corgi did a technical bulletin (217) which reckoned that there was enough adventitious ventilation to not need sleeving.
No dad I do what tony said...stick a bit of sleeving in either end to make it look good.
Read what I put dick, according to corgi you don't need to sleeve between floors and ceilings cos there's enough ventilation.
My question estate with medium pressure gas supply , inset meter box has pipe exiting through the back of the box through the spigot adaptor what would you be checking and classing it as
class as AR, pipe should exit bottom of meter box, also vent from gov should go down through bottom.
Too busy having a forum fight to answer daft gas questions.....which is just as well cos I didn't know that. :oops:
I got a question , can a gas pipe be installed in the cavity of a wall ??
as far as im aware of you cant install a pipe vertically in a cavity. bs6891 allows pipes to be installed behind dry lined walls(although still not in cavitiess of cavity walls.
were a gas pipe is to be installed behind a dry lining it has to be incased in some form of building material .. like wooden battons either side of the pipe and behind
Easy one transam yes you can but only when fitting an inset fire and shortest route possible must be taken
u cannot install a gas pipe in the cavity of a wall vertically, i think ur getting mixed up with passing through solid floors, then you should take the shortest possible route . very obvious reason
