I am fitting twin Siemens built-under ovens and a Siemens 5 burner induction hob. The ovens are rated at 3,200W and the Hob at 10,800W max.
The cooker circuit was wired 2 years ago with 6mm2 T&E and a 32A MCB. There is a 45A neon switch to the side of the oven housings above the worktop.
The question I have is, can I use the existing cabling to wire in the new appliances, as the total amperage is approaching 75(!) at max power (although it will rarely, if ever be at full load during normal usage)?
If I can use the cable, should I uprate the MCB, and if so, to what size - 40A, 50A and 63A are offered?
And finally, do I need two switches at the oven end - one for the ovens and separate one for the hob, spurred off the incoming cable before it reaches the switches?
I'm worried that I will need a separate cable run in, or at least, replace the 6mm2 with 10mm2. This will require a lot of carpet lifting, etc and the house has just been decorated!
Any help and advice gratefully received.
