Not I.Would you like to join me behind the sofa?
I find at my age that the carpet burns on my knees take too long to heal.
William - I suggest you read all of that thread before deciding whether or not to take electrical installation advice from Gaz.
Someone could remove a socket, join the wires OR NOT and fill with plaster.If the cable went through the box, and in there it had been cut and the cut ends joined in a connector block (or Wagos, or whatever), someone who didn't like the look of the blank plate could remove it, and fill the back box with plaster.
That's all true, but there's a limit to how far one can/should go in trying to anticipate the behaviour of idiots.If the cable went through the box, someone who didn't like the look of the blank plate could remove it, and fill the back box with plaster. If the cable went through the box, and in there it had been cut and the cut ends joined in a connector block (or Wagos, or whatever), someone who didn't like the look of the blank plate could remove it, and fill the back box with plaster.
No, we do not.Someone could remove a socket, join the wires OR NOT and fill with plaster.
We do not have to cater for future idiots.
Just a thought from a total numpty. Would it be acceptable to put a 2 Amp socket (e.g. https://www.tlc-direct.co.uk/Products/MKK0770.html) on a lighting circuit ? If so, that would give you a connection which could only be used for currents within the circuits capability.
Yes, but stop calling it a lighting circuit. It could be a fan, shaver, smoke alarms and light circuit.Just a thought from a total numpty. Would it be acceptable to put a 2 Amp socket on a lighting circuit ?
Theoretically, but the way things are getting a bit silly here, someone is likely to ask "What if someone puts a 2A plug on their large hadron collider and plugs it in?"If so, that would give you a connection which could only be used for currents within the circuits capability.
