I asked Vaillant about which flow temperature to set considering that I'm using a VSmart and this is their reply:
"if you have a combination boiler, then a suitable flow temperature for the heating would be between 55 and 65 degrees as this allows the boiler to remain in a condensing mode which is when it runs at its most efficient."
I thought that the temperature should be set higher to let the VSmart operate with the full range
