vauxhaull movano van
22 Nov 2011
hi anyone, the timing belt went on the van, now fixed. the van has been off the road for three months. it will turn over but not kick into life. any ideas. is this a problem with the imobiliser or what. glad of any help. ray
what year and size of engine? Is the immobilizer light flashing rapidly on the dash when cranking, if so it's the immobilizer. if not could be crank sensor needs cleaning. Have you check if there's fuel a the injectors?
I assume that any damage to the engine was repaired before the new belt was fitted.
Peter
thanks for the help i will check on these items. surfray
Peter
hi peter, thanks for the reply. yes the damage was repaired just dont know why it wont fire up.
thanks. surfray
Presumably whoever repaired it started so under what circumstances would it not start?
Peter
Peter
it just seems to keep turning over without actually kicking into life.
i have to go and see the guy tonight again and try to get more info from him.
Does it have an in tank fuel pump, if so can you hear it running for a few seconds when you turn the ignition on?
