    Dismiss Notice
Veritas R8 zone disablement?
Discussion in 'Alarms, CCTV & Telephones' started by houstonwehaveaproblem, 25 Nov 2018.
  1. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    one of the zones on my veritas is the door contact for my garage up and over door
    When the system is unset and i open the door it sets a tamper alert
    Is there a way i can isolate this before i open the garage door to save me having to turn the tamper off after the door is opened??
  2. Sponsored Links
  3. Handymanjo
    Handymanjo
    2 Feb 2016
    1,447
    Thanks Received:
    267
    Newark
    Country:
    Tamper are a 24 hr.
    Has it always done this.
    If not fault cable,loose cover on junction box etc
  4. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    Its always been set up like this.
    Even if the alarm is unset the garage door being opened triggers the panel to alert us via a tamper. Zone 8 red light comes on.
  5. sparkymarka
    sparkymarka
    16 Feb 2011
    7,768
    Thanks Received:
    1,190
    Sheffield
    Country:
    External keyswitch
  6. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    Cant be done at the panel?
    Anyway i can change the programme to remove this?
  7. Handymanjo
    Handymanjo
    2 Feb 2016
    1,447
    Thanks Received:
    267
    Newark
    Country:
    Change the programming to 12hr zone then program that zone as chime .
  8. sparkymarka
    sparkymarka
    16 Feb 2011
    7,768
    Thanks Received:
    1,190
    Sheffield
    Country:
    That's if it's on a zone and not on a global tamper ....did a question get removed ? ......
  9. secureiam
    secureiam
    20 Jun 2014
    4,225
    Thanks Received:
    513
    Lancashire
    Country:
    so the garage door is on Zone 8, so you can program the zone up to guard and place it on chime, this means when its set it will go off into alarm when unset it will activate the chime.
  10. Sponsored Links
  11. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    Thanks.
    How is this done?
  12. Handymanjo
    Handymanjo
    2 Feb 2016
    1,447
    Thanks Received:
    267
    Newark
    Country:
    If garage door is on zone 8 you will need the engineering code to change the option.
    You will program the zone as an alarm zone.
    If no engineer code this can not be done with out the code.
    Option then would be get installer in if installed by someone or default panel to reset engineering code.
  13. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    I have the code.
    How do i change the zone? What am i changing it to? Guard?
  14. Handymanjo
    Handymanjo
    2 Feb 2016
    1,447
    Thanks Received:
    267
    Newark
    Country:
    Yes
    In engineering 18 ,3 prog, if on zone 8.
  15. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    Strange. I changed it to guard but it still brings the tamper up
    • Thanks Thanks x 1
  16. secureiam
    secureiam
    20 Jun 2014
    4,225
    Thanks Received:
    513
    Lancashire
    Country:
    Okay what zone type was zone 8 set to originally?
    Only need the number.
    Take a picture to verify the condition on the keypad
    Do you have a Veritas r8 or r8 plus.
    If R8plus then you can have tamper on individual zones, this would then suggest you may not have the contact set up correctly.
  17. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    Not sure which model it is.
    Unsure of what the zone was set to originally.
Loading...
Share This Page
