Agreed, and for that purpose, you can use any electrical conductor (wire/cable) to 'extend' your lead - e.g. just a length of cable/wire you have lying around..... as a DIY'er I think that's adequate as in most instances, I am looking to trace cables and make sure there aren't any broken links. Assuming you agree with this, I would like to extend this capability my introducing a wander lead which is required in most instances as the probes only stretch around a metre apart.
In fact, one approach is to use a mains extension cable drum as that 'conductor' to extend the test lead, which is what I usually do. One can easily 'improvise' but I actually have a pair of Kewtech adaptors designed for that (which I use with a a 25m or 50m 'cable extension drum' (the mains extension plugs into the right-hand one and the left hand one plugs into one of the outlets on the mains extension lead) ...
What Harry has suggested is sometimes an option but (as I'm about to write) has its limitations.A few of you have suggested an earth lead to play this role but does it get damaged and become a trip hazard? They also don't have the crocodile clips to snap on to one end of the cable. I'd like some advice around this please.
Kind Regards, John
