What to Show as Existing?
13 Apr 2015
Hi Guys, A quick question for you, I have planning permission for a single storey rear extension (about 1/3 width of existing house) and a double storey side extension. The side extension is nearly up to the roof wall plate level and will continue until completed, the foundations for the rear extension are in and blockwork is going up (the foundations are fine for two storeys) and the bricky's will stop just before lintel level.
I want to put a planning application in for increasing the single storey rear extension to two storey. Or a two storey extension instead of a single if you like.
So my question is what should I show as existing when I submit my plans with the new application? Should I show the side extension as existing or leave it off completely or what?
Hi ^woody^ thanks for replying, the single storey bit would only be up to about 6ft obviously with no doors/windows internal walls etc, so you're saying show that as a existing? A half finished shell?
If you are applying for the first floor extension, then presumably a ground floor extension will need to be in existance first to build off.
If you leave the ground floor off the application, then you are effectively applying for a two storey and might not get it.
That's a fair point though if the planners make a visit (as it cannot be seen from the road so they may well do) they will see that the extension is just a shell and the existing drawings do not actually reflect what is there? Or do you think I should be saying to them in say a covering letter that construction is underway and the ground floor extension will be finished no matter what (which it will)?
So you're saying apply for adding a storey on top of the ground foor extension?
Not apply for a two storey extension per se?
We had something similar on here recently.
I usually draw it up as if the extension is existing but add a discrete note somewhere on the drawing saying "under construction" or "work in progress" or "phase 1" whatever best serves your purpose.
If the single storey rear extension already has planning permission the planning officer will check all previous applications anyway so it is all rather academic really (assuming you built it in accordance with the approved plans).
No need for that, you just write a one sentence text annotation on the plan.
The planner is interested in what the applied for extension will look like when everything is done and things can be assessed in context.
