Something I have done a quite a few times is use a normal wood hand saw to cut two slits side by side as wide as needed to accommodate the cable or trunking then use a hand chisel to chisel out the bit between the slits which should then chisel out quite easily. This way minimises the dust, another trick is to tape a shoe box to the wall just under where you are working so that the bits that fall do not fall a long way and hit the floor in a could of dust and keep moving it up as you go.
Yes the saw looses it teeth as they wear down quick doing that but its that saw that I replaced because it had lost its edge but I did not throw it away
You used a saw to cut through plaster and bricks????
