Willis Heating System
So, thanks to you, I think I've now got my thinking straight about this, and do now understand 'how it works'.
Phew, got there atlas.
However, I'm still inclined to stick with what I most recently wrote - namely that I don't really see what advantage this external heater offers over having an immersion within the main tank at the same height (above base of cylinder) as the external one - do you?
OK... The difference/advantage is that, your usual immersion heater, to some extent, due to circulation, is trying to some degree, to heat all the water, above the bottom of the element. You get little choice on this, it's all, or none. Immersion elements have limited lengths, and only the water above the bottom of the element will be heated.
The Willis, can heat a very limited amount, with the hot water all concentrated just at the very top of the main cylinder. You have the choice of anywhere between a little, or a lot. The Willis is also able to heat all of the water in the main cylinder down to where the Willis cold connection joins the main cylinder at the bottom. That would add perhaps an extra third to my stored hot water capacity, over the existing amount...
At the moment I normally use my gas boiler, which heats much more water in the cylinder, and of course is cheaper to run, than does the immersion heater in the same cylinder, because the boilers coils, are located below the end of the immersion element.
I actually think I do understand, and I certainly have the ability to identify statements/assertions that I believe to be incorrect - but I just fear that I am perhaps 'missing something', since so many people (at least, in Ireland and NI) seem to have bought into the idea of the 'system' concerned.
However, the more that people fail to present me with an argument to the contrary which I can understand and accept, the closer I come to believing that I probably am 'correct' in my thinking and that a lot of these thoughts about the Willis system may be little more than 'myth', created by people who don't adequately understand the physics.
Despite that, I remain open-minded, so would welcome any credible explanations about 'what I am missing' (not just assertions of views that differ from mine!)
I agree - I would love someone would come up with an explanation as to why it actually works and I could have a blinding "Road to Damascus" experience and shout Eurika etc , after all just because I do not (yet) get it, does not mean that it does not exist. I do not see a way that it is remotely tangible! What am I missing?
Obviously, I don't have such a system, and have never come across one in a domestic situation, though I have certainly seen similar in commercial/industrial locations. Work, it certainly does, as has we have tried hard to explain both the theory, and practical sides to John and anyone else watching the thread.
Actually, just to put the record straight.
I see two options - those in favour of the Willis wing the arguement by proving it.
Myself (and John) show it can not be proved.
I actually prefer that first option to come about if I have any choice about it.
I can envisage (slightly) one small difference with a Willis could be achieved by positional layout - the water leaving the Willis after heating could move at a higher velocity therefore perhaps "overshoot" a little before settling, I do envisage the overall difference being difficult to measure as a potential advantage though (alternatively, it could just be something else that I am wrong about).
Some years ago I met a problem I could not solve and it drove me half mad, but did eventually solve it by completely not thinking about it for a few days. One day, suddenly whilst looking in the mirror, shaving - I had that "Road to Damascus Event" , hey presto I got it (It was the "Monty Hall Conumdrum) simple once you got it and you kick yourself for not getting it earlier, you wonder how come you did not get it - will this one be another one of those???
No, the Willis principle is simple, and fairly obvious how it works.
Are you asking 'us' to prove that hot water rises?
Are you asking 'us' to prove that central heating systems can work without a pump?
