Wired v wireless
Our wired alarm was fitted by me about 30 years ago and it’s still going strong. Never been burgled or had an attempted burglary. I replaced the outside bell box and siren about 10 years ago and it now incorporates a night rider style strobing sequence led. Fitted a new indoor sounder as the old one 'yellowed'. Replaced the PIR's to pet friendly ones about 15 years ago when we had a cat and fitted a new front door contact when we changed the front door. Oh, I’ve also changed the battery in the panel a few times and recently changed the code on the keypad from 0123(!) because we'd worn the numbers off the buttons. And no, it’s not 5678 now! It’s the Triggers broom of alarm systems. :ROFLMAO:
We had a wireless system in our home garage and we had a wireless system in our villa in Spain. Both were useless, gave numerous false alarms and needed frequent battery changes.
Is the concept with the 12 core to the keypad ? The later ones only needed a 6 core …
I have an old but well built alarm built by Gardiner. I upgraded the PIRs to multi trigger units and that dealt with false alarms. I also added smart functionality using an esp32 controller which means I have a key fob, email alerts and a web interface to set/unset the alarm and check its status. It was a COVID project.
I'm struggling, with this kit, to understand, the need for no less than three noise-makers...
All, very loud - there is the outdoor bell box, the control panel itself, then a siren on the end of a 2.5m cable, which has to be plugged into the control panel. I'm thinking, to not bother installing the indoor siren, as it's just unnecessary. Apart from those, we get the phones being triggered too.
I disagree Harry. The inside siren is as important as the outside bellbox 1/ to let you and or Sykes that there has been a detection (or 2/ say a fault such as cover removed or cable cut etc in the Unset/Off condition) . Keypad beep could be a help in setting or unsetting or a power cut alert too.
Then if you have some sort of signalling such as mobile phone(s) or Landline(s) etc all the better too .
I see that order as the simple basics in any system, to which can be added signalling, floodliting etc etc , cause Sykes to increase risks of being seen and heard is the simple basics of any system at all.
