Wireless Alarm - Texecom or Scantronic, or Other?
9 Apr 2012
Hi all,
I need a wireless alarm, and it needs to be installed within the month, so I'm looking for someone else to do it, that knows what they're doing (because I clearly don't when it comes to electrics) and safe in the knowledge that all is ok, safe and working!
I would like additional functionality and control (via iPad or Internet), but above all I want a damn good alarm system!
CCTV is also desired, but I guess that is seperate from the alarm system...
I have had 4 quotes so far:
- Texecom Ricochet
- Scantronic 9751
- Scantronic K55
- Honeywell Galaxy
OPTION 1 - TEXECOM RICOCHET
7 x Texecom ricochet wireless PIR / 75.00 ea / 525.00 sub-total
2 x Texecom 3E External Sounder / 29.00 ea / 58.00 sub-total
1 x Texecom Premier Elite Flush Mount Keypad Satin Chrome / 129.00 ea / 129.00 sub-total
1x Texecom Wireless Ricochet Expander 32w / 89.00 ea / 89.00 sub-total
1 x Texecom Premier 24 Panel / 85.00 ea / 85.00 sub-total
1 x Internal Speaker / 14.00 ea / 14.00 sub-total
3 x Remote key-fobs / 26.50 ea / 79.50 sub-total
3 x Radio Base smoke alarm installed / 70.00 ea / 210.00 sub-total
1 x Installation and set up / 300.00 ea / 300.00 sub-total
GBP Total £1,489.50
Includes:
- speech dialler is in with the price of the panel, for both sms and the preferred option of speach dialling;
- Wintex software and set-up;
Excludes:
- door contacts
Questions:
- What PIR's are they? Texecom Prestige XT-W or QD-W?
- Whats the "Quad" difference, and recommended?
OPTION 2 - SCANTRONIC 9751
7 x Radio Scantronic PIR and microwave movement detector (12 meters x 90 degrees detection)
4 x magnetic door contacts
1 x Scantronic 9751 40 circuit control panel complete with a
standby battery giving 12 hours of operation in the case of mains failure
1 x Scantronic 9943 Remote Keypad
3 x Remote key-fobs
1 x Texecom Odyssey External Sounder 110db
1 x Texecom dummy bell box for rear
1 x Additional boxed 12volt loudspeaker, fitted nr control panel 90db
1 x 16-way radio extension module
1 x Speech Dialler
GBP Total £1,120.00 + VAT = £1,344
Excludes:
- Smoke Detectors
OPTION 3 - SCANTRONIC K55
7 x Radio Scantronic 714 PIR and microwave movement detector
4 x wireless door contacts, Scantronic 734R
1 x Scantronic K55 control panel complete with a standby battery
1 x Speech Dialler (built in to control panel)
5 x Remote key- fobs
2 x Panic buttons, Scantronic 710R
GBP Total £1,471.50 + VAT = £1,765.80
Includes:
- Panic buttons
Excludes:
- Smoke Detectors
OPTION 4 - HONEYWELL GALAXY
an older quote from late 2010!
as above, with Galaxy 2 Control panel, and Galaxy PIR's etc
Menvier SD1 speach dialler
GBP Total £1,785 + VAT = £2,142
NOT EVEN IN CONTENTION due to price!
Includes:
- 3 shock sensors
What are your initial thoughts please?
GBP Total £1,489.50
Includes:
Excludes:
- door contacts
If I look at www.cts-direct.net
includes:
7 x Texecom Prestige XT-W Wireless Digital PIR / 51.47 ea / 61.76 inc vat / 432.35 total
2 x Texecom Odyssey 3E External Sounder with White Cover / 22 ea / 26.40 inc vat / 52.80 total
1 x Texecom Premier Elite FMK Satin Chrome Flush Keypad / 98.75 ea / 118.50 inc vat
1 x Texecom Ricochet 32XP-W Wireless Expander / 84.10 ea / 100.92 inc vat
1 x Texecom Premier 24 Metal End Station 8-24 Zones Grade 3 / 47.45 ea / 56.94 inc vat
1 x Pyronix Twin Alert Internal Speaker Sounder / 7.55 ea / 9.06 inc vat
3 x Texecom Premier Smartkey Wireless Iconic Keyfob / 24.99 ea / £29.99 inc vat / 89.97 total
4 x Texecom Ricochet Wireless Impaq Door Contact-W / 37.99 ea / 45.59 inc vat / 182.35 total
TOTAL £1,042.88
Includes:
- door contacts
Excludes:
- Smoke detectors
- speech dialler?
- installation & set-up
Use the Galaxy. My preference. You might have some issues programming though. Not the easiest to work with if your a novice.
Next the Texecom, then the Scantronic. But think about the I-on 30
http://www.alertelectrical.com/prod...&utm_medium=web&utm_campaign=google-base-feed Gives you a base line.
Two sounders will push MA limits so go SCB with one at least.
£300.00 for fitting? You may want to recheck that.
Is there an existing spur? Are you providing one with certificates?
Free access available, no furniture to move about?
You want a certificate for insurance for the system?
What functions do you want via IP?
Remote setting? Not a good idea.
Your CCTV with IP is a better idea for remote access.
Then you could also use video verification after an activation. Using an output from the alarm to the DVR.
I agree with ^^ Galaxy is the better choice, also a personal preference, Get it all good with the insurance. :D
Ok will do without the remote setting for the Texecom.
Not sure what Wintex software does then?
Furniture is not in the way.
Control panel location has working electrics already in the vicinity, and there is a spur.
Same for the bell box sounders, as the loft is converted.
Insurance wise, I found in my last house that insurance approved alarm ade no difference to the house insurance premium. So not bothered about a certificate, just want the peace of mind of security.
I questioned the installer of the Tex, and he said he could knock off £100 max from his quote overall.
Not sure what speech dialler he has in with the Texe 24 control panel for £85 inclusive?
wintex alows you to program the system without having to go through countless menus on the keypad control.
i have just bought the texecom usb com interface myself so i can take advantage of wintex.
Fitting a lot of them then?
Wintex is not worth purchasing for one system.
It makes sense when you have a few thousand systems, the same as other remote servicing suites. It is good to get a onsite printout, and you can be sure your engineers are doing it correctly .
your a cheaky sod lol, anyway some of my friends have took a interest in my texecom system, looks like quite a few texecom systems are going to be installed in my town soon.
Good, they are a decent system.
I like the RKP with the large text ( good for our older or less sighted clients), although Castle do a good display too. Some of the smaller blue backlit LCD`s are a bit difficult for the aforementioned. (Sorry Cooper).
The Dimension touch screens are nice but still a bit expensive. But having the capability for adding a picture to it is a nice touch.
How will they nick that?
They wont be able to see it when the tamper kicks in!!!
