Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Although that can be an issue when the supply comes from stored hot and cold water, AIUI (although I may be wrong), that should probably not be an issue with a combi boiler (or similar) - since the hot and cold supplies should, I think, both remain at the same pressure.
Exactly - as I said, with a combi boiler the hot and cold pressures will remain equal, even when flow is redfuced, so the hot/cold mix (and hence shower water tem) remains much the same.
The 'real problem'/danger can arise when one is using stored hot and cold water (not a combi) with no (or inadequate) thermostatic mixer and inadequate pipework. In that situation, it is possible that flushing a loo or turning on a cold tap somwhere can significantly reduce the cold (but not hot) flow to the shower, thereby potentially resulting in 'scolding hot' water coming from the shower head.
Well, I think that 'inadequate' is a pretty accurate description - although, as you say, the reason for the inadequacy will usually be poor design.
If a shower has it's own dedicated feed pipes from cold water storage tank and hot water cylinder, there will usually (but not always) be no problems of the type we are discussing. I presume that failure to do that is the 'bad design' to which you were referring.
Firstly, the boiler has no involvement with the cold supply to the mixer - they are not related, and there is no reason why they should remain either constant or at the same ratio.
Secondly, if the pipe taking cold water to the bathroom also serves the WC, then causing the cistern to fill will without doubt reduce the flow to the bath taps.
And every single person who has ever used a non-thermostatic mixer tap will assure you that very small changes in pressure of either supply can easily result in very large changes in output temperature.
A new combination boiler will do exactly the same as the existing one.
It's the flow rate to the property that is the problem, not the device that heats the water.
As for the doorbell interference the only option is to spend £10 and get one of the things. It may cause interference. It may not.
It's not really a "failure", unless you consider the fundamental choice of having a combi instead of stored hot water a fundamental failure.
It may well be that the OP's plumbing is badly designed for using with a combi shower, and that things could have been done differently (eg not have the WC share the same 15mm pipe as the bath taps. eg having the DHW from the combi in 22mm to a manifold and then separate feeds for bath taps and kitchen taps - maybe the boiler could deliver more hot water when called for). It seems odd not to have done more to look for a better design before doing decoration etc that makes pipework changes unwelcome.
I've just thought - how is that ever going to work in practice?
How would the person in the shower know that someone in the kitchen was reaching for the taps and that they should ring the bell to get them to stop reaching?
'tis true that wives (or other female partners) often fail to appreciate the practicality of sometimes combining shower and WC functions to avoid unnecessary flushes, or the eco-friendly philosophy of "If it's yellow let it mellow, if it's brown flush it down", but even so when trying to mix H&C at different pressures basic mixers, particularly bath tap ones, can be a right PITA for single people - often the smallest thing known to man is not the latest particle found by the LHC, it's the dividing line between cold and skin-flaying hot.
